fuel rail pressure regulator
2002 CHRYSLER VOYAGER
143,000 MILES • 2.3L • MANUAL
AMELIAMOMMA
i have a gas leak.
Feb 15, 2021 at 2:10 PM
CARADIODOC
  • 34,306 POSTS
What's the question? Chrysler's fuel pressure regulators have had an extremely low failure rate. Same with most other car brands. If you have fuel leakage around the engine, look at the rubber fuel lines that run between the body and the engine to see if they're dry-rotted and cracked. If you smell gas only when the engine and outside air temperature are real cold, suspect the rubber o-rings the injectors are clipped into have shrunk. If a steel fuel line is rusted through, you'll see and smell gas along the right side of the van.
Feb 15, 2021 at 3:32 PM
