Code P0203, where is the Fuel rail circuit 3 located?
2011 FORD ESCAPE
222,478 MILES • 3.0L • V6 • 4WD • AUTOMATIC
JOSH.JONES
MEMBER
1 POST
FOLLOW
Where is circuit 3 / fuel injector 3 on my vehicle? How are the injectors numbered? Can I get a picture of this diagram?
Oct 20, 2024 at 12:27 AM
CERTIFIED EXPERT
Yep, this ocde is telling you there is a bad connection @ #3 which usually means a bad fuel injector.
The code P0203 on your 2011 Ford Escape refers to an issue with the Fuel Injector Circuit/Open - Cylinder 3.
#3 is the last cylinder on the right side of the engine. Here is how to replace the fuel injector. Check out the images (below). Please let us know what happens.
