What's the history that led up to this? Did the engine stop running while you were driving? If it did, how did the engine act? Did it just stop as though you turned the ignition switch off, or did it sputter and surge for a while first? How do you know the fuel pump is running, and how long does it run when you turn the ignition switch to "run"? Have you checked for spark? If you need help with that, check out this article first:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Have you checked the diagnostic fault codes? If you haven't, I can help you with that.
Mar 15, 2024 at 7:58 PM
