So my "project" car has been sitting for a while, I finally got the time and resources to start my rehab. It had been a month since I started it. My battery was drained so I replaced it. Engine would turn over strong but not fire. I gave it a small shot of starting fluid and she wanted to fire. Fuel is relatively fresh "Non-Ethanol" treated with Startron. Replaced fuel filter still no start. Find blown 10A fuse (drivers side dash) for fuel pump, replace fuse almost fired up. no fuel or pressure at new fuel filter. Replace fuel pump vroom! fired right up! Check for leaks all good. Let it run for a bit and shut it off. Go out two days later (got busy at work) and it is back to just turning over and not starting. I checked the fuse and fuse is good. I need help through the woods on this one as it is very frustrating. Any advice will be greatly appreciated.
Thanks in advance.
sjcomm
Thanks in advance.
sjcomm
Apr 10, 2018 at 6:22 PM
