Fuel pump relay replacement
2004 LINCOLN TOWN CAR
69,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CHAIRMANOFTHEBOARD
  • 20 POSTS
Where is the fuel pump relay on this car?
I would like to swap it with another relay to see if it is bad.
Is there another relay that I can swap it out with?
Thank you for your assistance.
Sep 19, 2021 at 1:13 PM
SQM
  • 6,383 POSTS
The fuel pump relay is located in the fuse box under the hood (see diagram below).
First check the relay for any corrosion or burnt pin(s).
You can also test the relay.
Here is a helpful guide:
Are you having an issue with inoperative fuel pump?
Let me know of any questions.
Thank you.
Sep 19, 2021 at 1:28 PM
CHAIRMANOFTHEBOARD
  • 20 POSTS
Hi, thanks for the reply.
I will check into the relay first.
But yes, I am having starting problems.
car ran fine, tried to start it yesterday, seems like it wants to turn over, but doesn't.
Has gas, gauge works too.
It did this once before a few years ago, but the next day it started fine and was running fine until yesterday.
Thank you in advance for any advice you can provide...
Sep 19, 2021 at 10:34 PM
CHAIRMANOFTHEBOARD
  • 20 POSTS
Would I be safe to assume the fuel pump relay can be swapped out with the A/C clutch or the horn relays?
Sep 19, 2021 at 10:39 PM
SQM
  • 6,383 POSTS
As long they have the same pin arrangement and has the same value stamped on the base, yes.
Also can you hear the fuel pump come on?
Sep 20, 2021 at 6:12 AM
