Fuel pump relay removal?
1990 VOLVO 760
167,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
LNGRENN
  • 4 POSTS
I have a crank but no-start condition, and I want to pull out the fuel pump relay to diagnose my issue. The FPR failure is a common problem on this model and a good place to start the analysis. I have located the relay and done all I can to try to pull it out, but I can't even budge it. I believe it should pull straight up to remove it, but my Haynes manual says this model year and subsequent 760Ts have the FPR permanently attached to the relay board. There must be a way to remove it for testing or replacement. How can I accomplish this?
Dec 25, 2022 at 4:04 PM
The system relay (located in the center console behind the ashtray) is a combined function relay. It combines the fuel pump and fuel injection relay into one unit.
As far as removal, they are clipped in place. See pic 1 below. Take a small flat screwdriver and gently open the clip to release it from the holding pin.
The remaining pics are the diagnostics for the fuel pump relay circuit. I don't know if you needed them but thought I would add them.
Let me know if this helps.
See pics below.
Dec 25, 2022 at 9:18 PM
LNGRENN
  • 4 POSTS
Hi Joe, thank you for your speedy reply, and merry Christmas to you! I appreciate your answer, but your diagram and instructions refer to the Volvo 740, 940 some of the 760s (before 1988). The 760 turbos from 1988 and later had a different configuration, with the relays packed together on the main electrical board on the left side of the passenger compartment, between the passenger's feet and the ash tray area that was used on earlier models (see my photo, which shows the earlier configuration on the left and the new configuration for the 1988 and later 760s on the right).
While I used to have a 1988 740 non-turbo and was able to remove the fuel pump relay easily in that car, I haven't been able to remove the fuel pump relay from my 1990 760T, despite trying to pull it out as hard as I could (it's hard to even get a grip on it because it's adjacent to other relays on three sides and there's nothing to hook onto on the top side). As I noted in my original question, my Haynes manual says most of these relays, including the fuel pump relay marked with the "B", are "permanently attached to the board".
I'm guessing that I have to remove the circuit board the relays are mounted on, though I'm unsure how to do that. If I get that out, it might be obvious how to take the relay off the board. That might mean melting the solder, if that's how the relays were "permanently attached".
If you have a suggestion on how to remove either the relay itself, or the whole main electrical board so I can get at the relay, I would be very appreciative.
Dec 26, 2022 at 12:24 AM
LNGRENN
  • 4 POSTS
Joe, thank you also for the instructions on testing the ECU. I'd like to check the other components that go out more frequently before I have to try getting to the ECU, since that's less likely to be the problem than several of the other components.
Here is more information on my problems starting my 1990 760T. I have just completed an extensive tune-up on many of the basic components of the car. When completed, I still had a very rough idle, which I eventually discovered was a vacuum leak in the intake manifold. I installed a new intake manifold gasket and got the car running smoothly. But a few weeks after completing that job, I went out to start the car one morning and got no cranking or starting. I did some step-by-step troubleshooting and concluded the starter itself was bad. I bought a new one at the parts store and installed it (while lying on the ground under the car -- a tight fit and an awkward job), and the car started up perfectly, but this time it ran very rough again, with symptoms of another vacuum leak. After looking all through the engine for the vacuum leak, I discovered that the cover to the air manifold was on crooked and when I put it on correctly, the engine started easily and ran smoothly for about 10 seconds before stalling.
This is the situation I'm currently in: I can repeatedly start the engine easily, but it appears to lose fuel after about 10 seconds. If I give it more throttle, it speeds up for a couple of seconds but then stalls after all. The tachometer doesn't drop to zero before stalling, so it doesn't appear to be losing electrical power. I have tested the OBD type 1 diagnostics but get 1-1-1, meaning no faults detected. The service light is on when I get the car running. When I turn the key to ignition but not to start, I don't hear any fuel pump noise from either the in-tank primer fuel pump or the in-line main fuel pump -- I think both should be running for about 1.5 seconds to prime the fuel system. I don't understand how I can keep starting the car easily if the fuel pumps are not operating at all.
So I want to test the relays that could be causing the fuel to cut out. 1) The fuel pump relay, where I could jump the terminals to bypass the relay and see if the fuel pumps are operating if I could get the relay out of its socket. 2) The radio interference relay (antenna relay) is also often the cause of similar problems. I haven't even found where that's located on my car. 3) The rpm relay is mounted on the flywheel (in my car this has replaced the Hall sensor that was mounted on the distributor cap in earlier model years), and I will see whether I can jump that one while starting. 4) This is a coolant temperature sensor that could be causing the fuel to cut off after it runs for a while. 5) There is a throttle switch that adjusts spark and fuel after the engine starts. 6) There is an ignition module that has caused starting issue from some car owners. 7) There is a fuel accumulator (pressurized reservoir for the constant flow fuel system) that could be causing problems if clogged. 8) The air mass meter could be the problem, but I don't think these symptoms sound like it's the culprit. The main problem is that I'm not sure how to test these various relays, sensors and other parts, so I want to test the parts that most commonly cause this kind of crank but no-start symptoms.
I have tried to remove the main fuel pump to run jumpers directly from the battery to see if it is working (very briefly so I don't ruin the vanes), but I can't for the life of me get the electrical connectors off the fuel pump to remove it or even connect leads to it in place in its carriage under the middle of the car. It looks really simple to do, and I have tried several different pliers to squeeze in the release tabs while trying to pull the connectors off, but I haven't had any luck -- very frustrating. I feel like I'm close to finding the problem and fixing it, but I'm feeling stuck right now. I hope this long description helps you in diagnosing what my problem might be.
Many thanks!
Dec 26, 2022 at 3:00 AM
The information I provided is the only thing I am able to find. I checked through two professional manuals that both provided the same info.
If you look below, that is what I have for the removal of the fuel pump/system relay. They are very basic.
See pics below.
Dec 26, 2022 at 8:14 PM
