Fuel pump relay location
2010 CADILLAC CTS
80,000 MILES • 3.0L • 6 CYL • AUTOMATIC
COLLET WILLIAMS
  • 10 POSTS
Trying to locate the fuel pump relay.
Nov 1, 2018 at 9:35 AM
Good afternoon.
The relay is in the fuse center. I attached a picture for you to view and they are marked.
Nov 1, 2018 at 11:42 AM
COLLET WILLIAMS
  • 10 POSTS
Hi. My diagram does not have a fuel pump relay mark on it. Trying to send an image of diagram.
Nov 5, 2018 at 7:35 AM
The relay diagram I sent you shows fuel pump.
Which fuse box are you looking at?
Nov 5, 2018 at 7:43 AM
COLLET WILLIAMS
  • 10 POSTS
I sent a picture of fuse box diagram.
Nov 5, 2018 at 7:48 AM
COLLET WILLIAMS
  • 10 POSTS
Sent a picture.
Nov 5, 2018 at 7:51 AM
Where is this fuse box?
There is one under the hood, in the trunk and under the rear seat.
Nov 5, 2018 at 7:52 AM
COLLET WILLIAMS
  • 10 POSTS
I have no fuse box under the seat. The one under the hood has no relay for fuel pump.
Nov 5, 2018 at 7:54 AM
COLLET WILLIAMS
  • 10 POSTS
This fuse box is in the trunk.
COLLET WILLIAMS
  • 10 POSTS
2010 Cadillac CTS.
Nov 5, 2018 at 7:56 AM
In the trunk.
1 - Fuel Pump Flow Control Module (LSA)
2 - Data Link Resistor (LSA)
3 - Fuse Block - Rear
4 - Fuel Door Release Actuator (N08)
5 - Battery Current Sensor
6 - Battery
Nov 5, 2018 at 7:57 AM
COLLET WILLIAMS
  • 10 POSTS
Yes, I am not hearing my fuel pump engage. So I was trying to check fuel pump relay. Got codes P062B, P1682, P069E, and P0231.
Nov 5, 2018 at 8:03 AM
COLLET WILLIAMS
  • 10 POSTS
I do not see fuel pump relay.
There is no fuel pump relay only the control module. Here are the engine and fuel pump wiring diagrams so you can see how the system works.
Here is a guide so you can check for power to the pump to see if the pump is bad. Use the wiring diagrams below:
There are different locations for the fuel pump module here are all options.
Nov 8, 2018 at 11:37 AM
COLLET WILLIAMS
  • 10 POSTS
I have a 05 ford hybrid escape..code P1A10 powertrain control module . disaaable battery .
Nov 9, 2018 at 8:22 AM
Are you going to another car? If you are, please start a new question.
Nov 9, 2018 at 8:32 AM
Okay.
The 62 code is the key. you have a failed PCM and it needs to be replaced. That looks like it has set all the other codes as well.
p062b
P062B
Descriptor
Probable Causes
Engine Control Module (ECM)
1682
P1682
Descriptor
Probable Causes
EC Ignition Relay Feedback Signal Circuit Open or High Resistance
EC Ignition Relay Feedback Signal Circuit Short to Ground
p069e
P069E
Descriptor
Probable Causes
Transmission Control Module (TCM)
Nov 9, 2018 at 8:35 AM
TAYY
  • 10 POSTS
Hello, I’m trying to located my fuel pump control module for replacement on my 2017 Cadillac XTS for throwing out the codes P069e.
Mar 6, 2020 at 6:40 PM
This is a different car. Please post your new question here, you must be logged in.
Mar 7, 2020 at 12:22 PM
