So, I'm looking for the wire that connects the fuel pump relay to my car's computer (ECM). I referred to the service manual and from there I was able to find the location of the pin on the ECM connector. Furthermore, I was able to find the two connectors that connect with my ECM relay box where apparently the fuse is located.
The problem is that no actual fuel pump relay is visible. Only the 15A fuse for the fuel pump is visible. I don't need the fuse I need the relay and that specific wire from that relay that connects to the ECM.
How can I find that wire?
Apr 19, 2023 at 6:27 PM
