Where is the Fuel pump relay located?
2000 FORD COURIER
465,200 MILES • 2.5L • 4 CYL • TURBO • 4WD • MANUAL
ELLEYC27
Hi, I’m trying to figure out exactly which relay in my truck is the fuel pump.
Feb 21, 2023 at 3:29 AM
They don't make a 2000 Ford Courier in the US. Here is the location in a ranger maybe they are the same, fuel pump relay is in the main fuse panel under the hood, please check the images below to see the location.
Feb 21, 2023 at 8:06 AM
BORIS K
  • 836 POSTS
The fuel pump relay is located in the engine fuse block.
See image below, relay 5.
Fuse and relay information:
https://youtu.be/k_UkjChvvk4
Hope this helps.
Cheers, Boris
Feb 22, 2023 at 12:39 AM
ELLEYC27
I know they don’t have couriers in the US, I’m located in New Zealand. The power distribution box and fuse box are different to the Rangers and Mazda B2500 unfortunately. Does anyone have the Australian courier fuse diagrams?
Feb 22, 2023 at 10:03 AM
I forwarded this problem to our Expert in Europe to get you taking care of. BORIS K is one of our best!
Feb 22, 2023 at 10:04 AM
ELLEYC27
I asked a question about this a couple weeks ago but problem hasn’t been resolved.
I need to know where I can find the fuel pump relay in my 2000 ford courier 4x4 diesel it has a WL Turbo engine only in Australia and New Zealand I believe. I’ve checked the fuse box in cab and engine bay and also brought a manual for my car online but hasn’t got any diagrams or anything with the relay for my engine. Any help would be greatly appreciated.
Mar 6, 2023 at 10:15 AM (Merged)
The fuel pump relay on a 2000 Ford Courier with a WL Turbo engine is located in the engine compartment fuse box. Here are the steps to locate the fuel pump relay:
Open the hood and locate the engine compartment fuse box. It's usually located near the battery or on one of the fender wells.
Remove the cover from the fuse box to access the relays and fuses.
Locate the fuel pump relay. The position of the relay may vary depending on the specific model and year of your vehicle, but it should be labeled in the fuse box diagram on the underside of the fuse box cover or in the owner's manual.
Once you've located the fuel pump relay, you can test it by using a multimeter or a relay tester to check for continuity and proper operation.
ELLEYC27
Here’s the diagrams from the manual, doesn’t have anything about the fuel pump relay for the WL Turbo only F2 Carb with different wiring?
Mar 6, 2023 at 4:51 PM
The images are too small to read. Can you resize them and re-upload please?
Mar 8, 2023 at 9:44 AM
