I got a the car listed above Royale front wheel drive. fuel pump quit working so I changed it. you can hear the fuel pump kick on. now I thought it might had a clogged line, so I replaced the fuel filter under the driver's door and blue the lines out with air pressure clean. still no fuel at fuel rail, but you can hear the fuel pump turn on when you turn the key on going. thinking it's the fuel pump relay. where is that located? I can't find it under the hood.
Mar 29, 2019 at 9:05 AM
