Hello, the fuel pump relay is not clicking in. I have right at 12 volts coming from fuel pump fuse but I'm only getting 3.5 volts from the PCM. The PCM is new. I can jump the relay and the fuel pump will run but still no start. I checked voltage at the injectors and I'm only getting 3.5 volts. Also, the PCM relay does click in, both relays are new.
Aug 25, 2023 at 1:13 PM
