Fuel Pump Relay
1991 VOLKSWAGEN GOLF
120,000 MILES • 1.8L • VR6 • TURBO • 2WD • MANUAL
VWLOVEMK2MK3
The fuel pump will not come on unless u ground it at the relay at the dash.
Mar 29, 2016 at 2:27 PM
FREEMBA
  • 1,152 POSTS
If grounding fuel pump relay terminal #3 causes the fuel pump to run, suspect corrosion on the RED/YEL wire which goes from the fuse box(G1/3) to the Digifant Control unit. The ECU is located in the air plenum on the left side of the engine compartment under the windshield.
Mar 29, 2016 at 4:38 PM
