Fuel pump relay where does it connect under the dashboard?
2006 FORD RANGER
120,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JODIE PEREZ
MEMBER
1 POST
FOLLOW
I know where the fuel pump relay is located in the fuse box under the hood. Where does it connect under the dashboard?
Jul 11, 2024 at 2:56 PM
STEVE W.
CERTIFIED EXPERT
If you are asking about the control circuit for the relay, it doesn't really connect under the dash, it is controlled by the powertrain module mounted in the cowl panel on the right side of the truck above the engine. There is an inertia switch in that same area. No other control for the pump exists.
