I have changed the fuel pump and crankshaft sensor and fuel filter. There are no codes. There was 30 lb. Pressure on fuel rail. The car will start and then shut off right away. I have changed the relay for the fuel pump, and I jumped the relay, and it will pump up, so it works. But put the relay in and it will start and shut off. There is not enough fuel to keep it running. What will let the fuel pump put a little gas and turn off? Any ideas?
May 4, 2022 at 12:47 AM
