Car was originally diagnosed as fuel pump but that has been replaced, fuse is okay and swapped the relays from the fan control as they are the same, to see if it could be that and still no go. Now there is absolutely no power getting to the fuel pump itself and the gauge has stopped working. seems to be an intermittent power failure as when the battery charged the fuel pump kicked in and it started no problem. left it running for ten minutes turned off ignition then it wouldn't start again. fuel pump kicked in the first time and power was getting to the pump when it was voltage tested but now it is dead.
Jun 20, 2019 at 1:50 AM
