Does not start
2001 CHEVROLET PRIZM
270,000 MILES
AMANDA N JERRY LEDESMA
  • 10 POSTS
Car does not want to start. replaced starter, fuel pump, spark plugs. still does not want to start. could it be the fuel pump or fuel pump relay?
Sep 21, 2019 at 12:57 PM
Good afternoon,
Can you hear the fuel pump run when you turn on the key?
I would also check the spark to be sure it has spark to the plugs.
I would also check the compression to be sure there is not a timing issue.
Sep 21, 2019 at 2:38 PM
  • 10 POSTS
No, I don't hear the fuel pump turn on. And no spark.
Sep 21, 2019 at 3:02 PM
Okay, I attached a wiring diagram for you to view. Check the fuses listed for power on both sides for power with the key on. This is not a visual inspection, it is a voltage check.
There are 2 relays involved but testing must be done to determine the failure.
Sep 21, 2019 at 3:10 PM
  • 10 POSTS
All fuses are working. But no spark.
Sep 21, 2019 at 3:21 PM
  • 10 POSTS
Does my car have a fuel shutoff switch?
No, it does not. That would not allow spark.
Do you have a test light or voltmeter?
Sep 21, 2019 at 3:55 PM
  • 10 POSTS
Yes.
Sep 21, 2019 at 4:04 PM
  • 10 POSTS
Getting ready to buy a diagnostic device.
Sep 21, 2019 at 4:05 PM
What diagnostic device?
Sep 21, 2019 at 4:08 PM
  • 10 POSTS
Like the ones they use at AutoZone, to diagnose a problem.
Sep 21, 2019 at 4:12 PM
  • 10 POSTS
The fuel pump still does not turn on. what else can cause the fuel pump to not turn on?
Sep 21, 2019 at 4:14 PM
They are code readers. They will not help you at all. They will tell you a code but does not identify a failed part. Diagnostics and repairs need to be done to determine the failure.
What was the voltage at the fuses?
Sep 21, 2019 at 4:28 PM
  • 10 POSTS
Only have test light.
Sep 21, 2019 at 5:01 PM
Okay, go to the EFI relay and remove the relay and make sure there are 2 powers with the key on.
If there is, install the relay and see if it clicks or turns on.
Sep 21, 2019 at 5:11 PM
  • 10 POSTS
Okay, will check first thing tomorrow morning it is already dark out.
Sep 21, 2019 at 5:34 PM
Sounds like a plan.
Sep 21, 2019 at 5:45 PM
