Fuel pump not working without directly wiring
1993 PLYMOUTH COLT
100 MILES • 1.5L • 4 CYL • 2WD • MANUAL
JIMGABBARD58
  • 4 POSTS
Two problems the first is engine has been completely rebuilt all new but sensors 1. problem hesitation after warm up when acceleration hesitates bad. I think sensor but not sure which. it is not any other thing like timing or other has been before rebuild.
2. One day stopped able to start fuel pump not running but works if hot wired cannot find good wire diagram for location of pump relay or fuse. any ideas? help please.
Nov 23, 2017 at 7:26 PM
HARRY P
  • 2,292 POSTS
The pump is bad. When you run a hot wire to it, you end up with just a little extra juice getting there, helping it to get turning. This also explains the hesitation and bad running, as the fuel pressure is not as strong as it is supposed to be. To confirm, probe the lead wire at the fuel pump with a multi-meter. It should get some power when you turn the key on (two to three seconds) and when cranking. I will look up the location of the relay in a few minutes so you can check it (if there is no power at the pump) and post it below.
Nov 23, 2017 at 7:46 PM
HARRY P
  • 2,292 POSTS
Here is some information on the relay and how to test it.
Nov 23, 2017 at 7:58 PM
JIMGABBARD58
  • 4 POSTS
well your answer needed more information to get to the real problem
the hesitation only happened after warmup while cold the engine was spunky no hesitation, so the initial problem of hesitation can't be fuel pump although it may have gone bad later.
Nov 24, 2017 at 6:57 PM
HARRY P
  • 2,292 POSTS
The pump could be losing pressure as the car warms up. I have seen that happen on cars, even Chrysler products. I would still start at the pump and see if that hesitation goes away.
Nov 25, 2017 at 3:23 AM
JIMGABBARD58
  • 4 POSTS
I got to the plug for the fuel pump disconnected and turned key with probe light on not any voltage found the MFI relay will I need to take the whole dash out cannot find any way to get to It I am figuring relay or broken wire or connection. any thoughts?
Dec 17, 2017 at 1:29 PM
JIMGABBARD58
  • 4 POSTS
well got the MFI relay out and did testing as prescribed it's all good so what is telling the mfi to work possible new controle module ?
Dec 17, 2017 at 5:36 PM
HARRY P
  • 2,292 POSTS
I am phoning a friend on this one. I will follow up and do necessary research this evening if needed.
Dec 18, 2017 at 4:50 AM
If I may jump in here. It sounds like you have lost a power feed to the system like a fusible link is bad. Please use a test light and check for power on both sides of the link.
Here are the engine and fuel pump wiring diagrams so you can check power and ground of the system:
and
Check out the diagrams (below).
Dec 18, 2017 at 12:30 PM
HARRY P
  • 2,292 POSTS
Thanks Ken! I thought that I was missing something but couldn't put my finger on it. I think you nailed it.
Dec 19, 2017 at 4:00 AM
Teamwork! its what we do :)
Dec 19, 2017 at 1:00 PM
