Fuel pump will not run. Checked fuse, it is okay. disconnected line to the fuel filter, still no fuel. added a couple gallons to the tank and took a rubber mallet to it, still no run. Checked inertia switch, reset is made, swapped out 303 relay, tried new relay (both spots) under the hood by the power brake assist on the firewall. removed the radio to find only a flasher relay, not the fuel pump relay as instructed by the computer at "O'Reillys", with the key on the fuel gauge works, and cranking the engine over there is oil pressure, relieved pressure on the fuel rail.
Apr 18, 2018 at 3:19 PM
