Okay, so with the help of an assistant, can you please take a voltage reading at the fuel pump connector yellow wire with your assistant turning the ignition key to the "run" position. In the diagrams down below I have included a wiring diagram of your vehicle's fuel pump circuit. You will need to use a Digital Multi-meter to do this, so here is a link to a guide explaining how to use one below, if needed:
Please get back to us with what you find out, and we can go from there, if needed.
Thanks,.
Alex
2CarPros
Nov 12, 2019 at 5:37 PM
