fuel pump not depressurized
2003 OLDSMOBILE AURORA
140,000 MILES • 4.0L • V8 • FWD • AUTOMATIC
KENCO
After releasing fuel pressure from engine fuel rail and proceeded to remove fuel line from fuel pump, but was still pressurized and pushed out a lot of fuel. Should this have happend or is there a problem preventing the depressurizing of the fuel line?
Dec 23, 2015 at 5:57 PM
WRENCHTECH
  • 20,761 POSTS
Are you sure you didn't turn the key back on again for some reason? There shouldn't have been any pressure there.
Dec 23, 2015 at 6:01 PM
KENCO
Disconnected battery before starting project. Could a plugged fuel filter or line cause this. Am changing fuel pump because of low pressure .Could be because of problem in fuel pump.
Dec 23, 2015 at 6:34 PM
