Where is the fuel pump driver module located?
2017 FORD ESCAPE
97,530 MILES • 1.5L • 4 CYL • TURBO • 4WD • AUTOMATIC
Where do i find fuel pump driver module? no idea where to start looking on car.
May 29, 2021 at 9:54 AM
It is under the rear seat. I attached all the info below on this including the wiring diagram.
Please take a look at this info and let us know if you more and we will be happy to provide it.
Thanks
May 29, 2021 at 7:34 PM
DANNY L
  • 5,648 POSTS
Hello I'm Danny.
The fuel pump driver module is located under the right rear seat cushion underneath the carpet. I've attached a picture below. I've also attached a picture of the rest of the fuel system as well. Hope this helps and thanks for using 2CarPros.
May 29, 2021 at 7:38 PM
Does the 2018 Ford Escape use emergency fuel shutdown inertia switch? if yes where in car is it?
May 30, 2021 at 6:39 AM
No. If you take a look at the wiring diagram I added above you will see that there is a fuel pump control module and that will control the fuel pump if it needs to be shut off.
They stopped using the shut off switch some time back when the body control module and powertrain modules got more sophisticated.
Let us know if you need more info. Thanks
May 30, 2021 at 7:51 PM
DANNY L
  • 5,648 POSTS
Hello again.
To answer your question. No, your Escape does not have the fuel system inertia cut-off switch in case of a collision or accident. Ford eliminated that safety feature around 2015. Your Escape still does have the roll-over fuel tank valve however. Let us know if you have any further questions on this issue. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 1, 2021 at 7:22 AM
