fuel pump location
1981 CADILLAC DEVILLE
80,000 MILES
RANDY SHARP
  • 165 POSTS
Where is the fuel pump on a 1981 cad sedandeville 6.0 L 4-6-8 motor fuel injected?And where would be the fuse for it also?
May 1, 2013 at 10:01 PM
CARADIODOC
  • 34,306 POSTS
The pump is in the gas tank. check all fuses with a test light to verify power. Fuse panel under left side of dash. If you're checking for voltage at the pump there won't be any unless you're cranking the engine.
May 1, 2013 at 10:30 PM
RANDY SHARP
  • 165 POSTS
Ok thanks alot
May 1, 2013 at 10:32 PM
