Where is the fuel pump on a 1981 cad sedandeville 6.0 L 4-6-8 motor fuel injected?And where would be the fuse for it also?
May 1, 2013 at 10:01 PM
CARADIODOC
CERTIFIED EXPERT
The pump is in the gas tank. check all fuses with a test light to verify power. Fuse panel under left side of dash. If you're checking for voltage at the pump there won't be any unless you're cranking the engine.
