The debris I referred to is microscopic. It isn't anything you can see.
The next step is to do an autopsy on the pump you're removing, but that will likely void any warranty. You can start with the bench-test by connecting a battery to see if it runs. Be aware the brushes in the motor cause arcing which can ignite gas fumes. It's much too rich inside the tank for that to happen. An alternative to start with is to measure the continuity of the motor. If you find an open circuit, there could be debris that got stuck under one of those brushes. That might prevent the motor from starting up, but if it does get up and running, it should continue running until you stop the engine.
If you do connect a battery and you see a little sparking when you make the last connection, it proves current is flowing through the motor. It should be running unless the impeller is locked up.
If this current pump has never worked even once, given your other observation of the gas gauge not working, it would not be too farfetched to find the assembly is wired wrong. As a former manufacturer's instructor used to tell us, "we not only sell you parts; we sell them to you pre-broken". The wires are hand assembled into the connector. It's easy to see how a mistake could be made.
Since this pump did run for a few minutes, you might look in a different direction at what these have all had in common. Mainly I'm thinking of removing the tank and unplugging the connector. Look for a corroded ground wire that is making intermittent connection, and even better, check for intermittent connections in the connector terminals. I used to warn my students to never poke test probes into the connectors for fear of spreading them, leading to poor contact with their mating terminals. If the pump passes the bench-test, use small pick to squeeze the connector terminals tighter.
Another thing to look at is how the pump motor is grounded. GM used to have a really common problem with their motors being grounded right to the tank, then the connection back to the battery was made through the two metal straps holding the tank in. Those straps were notorious for bad connections. The fix for them was to drill a small hole through the flange where the top and bottom halves were welded together, outside that weld bead, then use a self-tapping screw or a small nut and bolt to attach a ground wire from the tank to the frame.
Let me know what you find with the bench-test.
Mar 16, 2024 at 7:37 PM
