Can I attach the electrical housing from the fuel pump to the ground wire from the fuel pump directly to the chassis?
1992 CHEVROLET 1500
160,000 MILES
The ground wire was on top, and the electrical housing was underneath it attached by a screw cannot get it to attached now.
Aug 13, 2023 at 5:54 AM
If I understand you correctly you can. You mean you want to ground the fuel pump module to the frame, correct? If so, you should be okay.
Aug 14, 2023 at 1:06 PM
