Fuel pump
2007 SATURN VUE
168,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSHUA DAVIAU
Fuel pump is good. Lines are all getting power but when you hook everything together the fuel pump does not come on. We have checked the pump outside of the tank and it works.
Sep 12, 2017 at 4:46 PM
SATURNTECH9
  • 30,869 POSTS
So the fuel pump does not run while cranking the engine or when you turn the key to the run position momentarily?
Sep 12, 2017 at 7:29 PM
