PO208 code, driving, engine light starting flashing, light stopped and went out, drove vehicle home, shut off, scanned, received code. will crank/no start unless I jump relay.
key off, fuel pump relay activated, can jump hot feed fuse side to ground side of ECM- fuel pump operates. disconnected ECM. relay still active. so ECM not problem. traced and tested all grounds. removed/cleaned and reassembled and re-tested, all good. dropped tank and removed connector at fuel pump. relay dis-engaged. have 12v going to gray wire on fuel pump. re-connected and tested ground side.(black wire) gray wire reads .048 volts; black wire reads .047 volts. possible causes? I cut black wire and gray wire goes back to 12 volt. if no ECM problem and no fuel pump problem and no ground problem could it be fuse block.
Aug 10, 2023 at 1:35 PM
