Where does the fuel pump ground wire attached to the vehicle?
1994 CHEVROLET 1500
150,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
GURUGARDENER
MEMBER
FOLLOW
Where is the fuel pump grounded?
May 12, 2022 at 9:13 AM
BORIS K
CERTIFIED EXPERT
The fuel pump ground is shared with the fuel pump relay. It is located at the left front of the engine.
See image below.
Hope this helps.
Cheers, Boris
Image (Click to enlarge)
May 12, 2022 at 9:34 AM
SQM
CERTIFIED EXPERT
The fuel pump is grounded to the chassis. You will have to trace the black/white wire to find the ground. It should be located on the left front of the engine compartment.
