I'm missing the fuse for the fuel pump in the fuse box which is located in the cab under the dash driver side, slot 15 20 amp fuse. Now i can hear the pump prime ehrn i turn the key sometimes. Not always. But even when I do in not enough fuel to the motor. Unless i step on the gas pedal, which doesn't always work either. I'm thinking i need to readjust the pedal took push it partly down the gas pedal works. I push it all the way down. Car bogs down until i let up. That happens when i drive and I idle.s. i can barely keep the car running at idle. Half the time because of the lack of fuel and which also includes a idle loop as well. Help me.
This car is awesome but it's a pain. I miss my Durango.
Jun 8, 2021 at 5:59 PM
