There is an issue with the Pass-lock security system. You may have damaged the sensor or sensor wires when the keys hit the lock. You may have to replace the ignition cylinder and then do a relearn to the system. The keys do not contain transponders.
Learn procedures:
There are two available methods to perform the programming procedure:
A ten minutes procedure which requires a Tech 2 and a tech-line terminal.
A thirty minutes procedure which does not require the use of any tools.
Ten Minute Learn Procedure
Tools required:
Tech 2
Tech-line terminal with current Service Programming System (SPS) software
Connect the Tech 2 to the vehicle.
Select "Request Information" under "Service Programming".
Disconnect the Tech 2 from the vehicle and connect it to a tech-line terminal.
On the tech-line terminal, select "Theft Module Re-Learn" under "Service Programming".
Disconnect the Tech 2 from the tech-line terminal and connect it to the vehicle.
Turn ON the ignition, with the engine OFF.
Select "VTD Re-Learn" under "Service Programming".
Attempt to start the engine, then release the key to ON, vehicle will not start.
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn off, the vehicle is now ready to relearn the Pass-lock(TM) Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK.
Turn OFF the ignition, and wait five seconds .
Start the engine, the vehicle has now learned the password.
With the Tech 2 scan tool, clear any DTCs.
Thirty minute Learn Procedure
Observe the SECURITY telltale, after approximately ten minutes the telltale will turn OFF.
Turn OFF the ignition, and wait 5 seconds .
Repeat steps 1 through 4 two more times for a total of three cycles/thirty minutes , the vehicle is now ready to relearn the Pass-lock(TM) Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Start the engine. The vehicle has now learned the Pass-lock(TM) Sensor Data Code and/or password.
IMPORTANT: The vehicle learns the Pass-lock(TM) Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Jan 20, 2017 at 5:56 PM
