Fuel pump delivery
1993 BUICK CENTURY
175,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
MECHANICNOONE
  • 7 POSTS
Positive wire on alternator touched metal. sparks and smoke came from ignition coil and module area. Now there seems to be no fuel delivery. Replaced all coil packs ignition module checked fuses all fuses good. What else could it be?
Dec 16, 2018 at 2:29 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
You might want to check the fusible link.It's normally located at the starter solenoid or on the positive battery cable pigtail.That acts as a circuit protection device when a major arcing like that happens it's designed to burn out saving the rest of the electrical system from damage.
This guide can help you test for power:
Hope this helps and thanks for using 2CarPros.
Danny-
Dec 16, 2018 at 3:06 PM
MECHANICNOONE
  • 7 POSTS
What does a fusible Link look like?
Dec 16, 2018 at 3:21 PM
DANNY L
  • 5,648 POSTS
Hello again,
I've attached a picture of what a fusible link looks like.They are available at all local auto parts stores.Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 16, 2018 at 10:24 PM
