What could make a car start idle and shake and then it turn off?
1999 GMC JIMMY
167,579 MILES
NINETTE75
MEMBER
FOLLOW
If the fuel pump is working and the fuel filter is fine what else could make car start idle and shake and then it turn off?
Sep 30, 2022 at 10:11 AM
CERTIFIED EXPERT
This could be the IAC motor, vacuum leak, bad spider injector, weak fuel pump. bad PCM for starters. Let's start by running the codes this guide can help:
