Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Ram
Fuel System
Fuel Pump
Fuel pump swap with universal inline fuel pump
1998 DODGE RAM
270,000 MILES • 0.6L • 6 CYL • 4WD • AUTOMATIC
CELAM7939
MEMBER
FOLLOW
Will a universal inline fuel pump work on the truck listed above 1500 4 door truck?
Jul 10, 2019 at 2:01 PM
CERTIFIED EXPERT
Good evening,
It needs to be a pump that is regulated to 50 lbs. That is what your truck requires.
Why not replace the pump in the tank?
A pump from rock auto is $48.00.
Jul 10, 2019 at 2:45 PM
CELAM7939
MEMBER
Where is rock auto and how can i get it?
Jul 10, 2019 at 2:46 PM
CELAM7939
MEMBER
And is that all i need to do and the truck will be working?
Jul 10, 2019 at 2:47 PM
CERTIFIED EXPERT
Go to there web site. Put in your truck and go to the fuel pump. They usually deliver the next day.
I attached the picture of the pump for you.
Jul 10, 2019 at 2:48 PM
CERTIFIED EXPERT
I assume so since you asked for it. Did you determine it was failed?
Jul 10, 2019 at 2:49 PM
CELAM7939
MEMBER
Yes it is the fuel pump.
Jul 10, 2019 at 2:50 PM
CERTIFIED EXPERT
Okay, contact them for your pump.
Jul 10, 2019 at 2:55 PM
CELAM7939
MEMBER
Is it possible that the filter for the fuel is bad? and it shows the same symptoms of a bad fuel pump.
Jul 12, 2019 at 4:07 PM
CERTIFIED EXPERT
No. There is a bypass in the filter.
Jul 12, 2019 at 4:21 PM
