Fuel pump will not shut off
1990 FORD BRONCO
150,000 MILES • V8 • 4WD • AUTOMATIC
BRONCOLOST
  • 4 POSTS
The fuel pump wont shut off until it drains the battery or the battery is disconnected. I can't figure out the Chilton book. Need to know where the fuses are and the power wires.
May 5, 2019 at 4:58 PM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like you have a short to power somewhere in the wires going to the fuel pump which is located in your vehicle's fuel tank. Does your vehicle have 1 or 2 fuel tanks?
Thanks,
Alex
2CarPros
May 5, 2019 at 9:59 PM
BRONCOLOST
  • 4 POSTS
It has one tank.
May 6, 2019 at 1:49 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
In the diagrams down below I have included a wiring diagram for your vehicle's fuel pump as well the exploded diagram of the pump and a description of the EFI system. With the ignition key off I want you to take a voltage reading pin #86 of the fuel pump relay. I have included a link below if you are unfamiliar with how to use a multimeter.
Please get back to us with what your voltage reading and we will go from there.
Thanks,
Alex
2CarPros
May 6, 2019 at 3:09 PM
BRONCOLOST
  • 4 POSTS
The battery is completely dead and will not hold a charge because I didnt charge it during our cold Alaska winter I have to buy a new one next payday. I will have to get some help. To do the reading dont have a meter. I will let u know when it's done. Michelle
May 7, 2019 at 8:20 AM
May 10, 2019 at 10:43 AM
BRONCOLOST
  • 4 POSTS
I will.
May 10, 2019 at 10:12 PM
