Recently rebuilt a 390 motor in a 73 f250. Fuel pump is brand new. Started it up after I installed the motor and it ran great while I made all my timing adjustments, checked for leaks, etc. Two days later, it is not getting any fuel to the carburetor. I changed the filter and still nothing. I disconnected the line from the pump to the carburetor and barely a drop or two is coming out of the pump when it turns over. Is there a filter or screen in the fuel tank that could be plugged? The truck sat for some time before the rebuild so that would make sense. Help!
Update: disconnected the intake side of the fuel pump, connected a temporary line, and put it in a gas can. It would not draw up any fuel or create suction. could the pump be full of debris from the tank or just a defective fuel pump?
Dec 23, 2017 at 1:34 PM
