Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
S-10
Fuel System
Fuel Pump
Replace/Remove
Stalling and will not start after replacing the fuel pump
1994 CHEVROLET S-10
4.3L • 6 CYL • 4WD • AUTOMATIC
FFFFFFFFF
MEMBER
1 POST
FOLLOW
I changed the fuel pump, and it keeps stalling and won't start like it's not getting gas.
Jan 14, 2022 at 6:19 AM
CERTIFIED EXPERT
Good morning,
Can you hear the pump run when you turn the key to the on position?
You need to check the actual pressure. You can rent a tester at a parts store and the fitting is right by the distributor.
Image (Click to enlarge)
Jan 14, 2022 at 7:08 AM
