Will not start
2002 FORD F-250
150,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
ICED
Installed fuel pump and still will not start. I was told the relay is integrated into fuse box under dash and was told fuse box will need replaced.
Jul 15, 2018 at 3:29 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Have you checked the fuel pressure after installing the pump? I have attached a link how to test. Most auto parts stores have a tool loaner program to loan/rent the tester. Your vehicle should have 35-45 PSI. Hope this helps and feel free to ask any questions if needed. I can also include specifications of diagrams if needed. Thanks for using 2CarPros.
Danny-
Jul 15, 2018 at 4:50 AM
ICED
All was checked and still no starting,
Jul 15, 2018 at 5:03 AM
There is a fuel pump relay located in the fuse panel under the hood. Here is a guide to help you test it:
Jul 17, 2018 at 2:34 PM
