P0453 - EVAP Emission System Pressure High
P0455 - EVAP System Leak Detected
P0581 - Cruise Control Multifunction high
U0109 - Lost communication with the fuel pump module
P025A - Fuel Pump Module Control Circuit open
This is kind of what I suspected. You have a wiring issue. I would focus on the P025A and U0109. The other codes are not going to cause the fuel pump issue.
I attached the test that you need to follow. It is lengthy but should take you to the issue.
Dec 11, 2019 at 4:50 PM
