fuel pump location
1991 TOYOTA CAMRY
150,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
LOFTIS
found where pump assembly should be but all I found was the float.
Mar 6, 2021 at 2:00 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial for you to view on how to replace an in-tank electric fuel pump:
You will need to remove the fuel tank to gain access to the fuel pump. I've attached picture steps below on how to remove and replace both the fuel tank and fuel pump on your car. hope this helps and thanks for using 2CarPros.
Mar 6, 2021 at 2:28 PM
