fuel pump low fuel pressure
1981 TOYOTA PICKUP
70,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
FIRSTHD
  • 17 POSTS
I have low fuel pressure.
It is a mechanical fuel pump. Is it possible to add an electrical fuel pump along supply line?
Sep 25, 2016 at 9:12 PM
WRENCHTECH
  • 20,761 POSTS
That would be a very expensive proposition to get it regulated properly. Just find an repair the problem with your mechanical system. Make sure you do not have a rotted rubber hoses anywhere because it will make the pump pull air instead of fuel.
Sep 26, 2016 at 4:52 AM
FIRSTHD
  • 17 POSTS
thanks that helps.
Sep 26, 2016 at 5:49 PM
