I need the fuel pump assembly schematics
2002 CADILLAC SEVILLE
129,000 MILES • 4.6L
BRANDX
  • 5 POSTS
The car listed above has a Northstar motor. When trying to replace the fuel pump the wires on the plug for the modulator sending unit became unplugged.
Please.
Nov 18, 2019 at 5:06 PM
Hi:
I attached a picture of the connector which includes pin identification, wire color, and what each wire is for. Let me know if this is what you needed.
Nov 18, 2019 at 8:22 PM
BRANDX
  • 5 POSTS
Helps somewhat. can i get a diagram of a fuel pump for 2001 Cadillac Seville Northstar fuel pump replacement? need to rebuild one so need the break down of components.
Nov 19, 2019 at 2:04 AM
BRANDX
  • 5 POSTS
The ECM or level sensor has separated from the main fuel suction motor and not sure what wires go where on the 4 pin plug fof level sensor on replacement.
Nov 19, 2019 at 2:17 AM
BRANDX
  • 5 POSTS
Also, would like to check the inertia switch or fuel shut-off switch on a 2002 Cadillac Seville on the Northstar motor but don't know its location.
Nov 19, 2019 at 2:31 AM
Hi:
This vehicle doesn't have a fuel cutoff switch. The fuel pump runs for 2 seconds when the key is first turned on in order to prime the fuel rail. The pump also runs during cranking, and when the engine starts and is close to idle speed, the pump is stays on via the PCM.
Nov 19, 2019 at 7:13 PM
