Fuel problems
1992 FORD AEROSTAR
170,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MARVIN OLSON
  • 9 POSTS
Went to start vehicle but just flooded so bad filled cylinders with gas and drained into the oil pan. I kept trying it and finally would not fire. Figured out through the internet the fuel pressure regulator went on it was bad changed it but will not start now. More from the internet found the EEC power relay tested okay. checked the fuel pump relay the test explained to check number two and number four wires are okay. When I jumper number three and number four wires to manually activate the fuel pump this is not supposed to start the fuel pump until I turn the ignition key on but it starts the pump with the key off. Would there be something in the ignition that is sending power there all the time?
Mar 27, 2018 at 6:24 PM
Couple questions you say the fuel pump runs all the time no matter what? and what do the spark plugs look like can you send me a picture?
Please let us know.
Mar 30, 2018 at 10:48 AM
MARVIN OLSON
  • 9 POSTS
Thanks for getting back. The pump keeps going when I do the test. Power when I jumper the wires should just be when the key is on. The plugs were pretty good and I put new ones in now. Old ones gone
Mar 30, 2018 at 4:24 PM
Okay, does the engine sound normal when cranking it over? can you send me a video so I can see whats going on? Lets run the codes to see what comes up.
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Please run some tests and get back to us.
Mar 31, 2018 at 11:51 AM
MARVIN OLSON
  • 9 POSTS
Thanks again. I will try to do get some codes. I had the battery posts unhooked so might of lost the codes.
Mar 31, 2018 at 4:24 PM
Connect the battery and try and start it then run the codes if something is really wrong it will tell us.
Apr 1, 2018 at 3:58 PM
MARVIN OLSON
  • 9 POSTS
I got time to try starting my aerostar van finally but not sure if anything is close to being right.I just had a test light so hooked it up the way you explained and hard to figure out but what we got over and over was 2 long and 6 quick flashes then 1 long and 5 quick flashes then 9 quick flashes then 2 long and 4 quick flashes.This would repeat over again one more round of all then seemed to flash 7 long ones or 4 long and bit of a hesitation then 3 long then would just stop.I am not sure if this is close but we counted with the test light many times and the engine light on the dash was the same flashes over and over.I have a digital meter but read it needed an analog meter to do it. Thanks for being patient and continuing to answer.
Apr 2, 2018 at 6:02 PM
O man, It seems like the computer is having a problem the codes are all over the place, Check the power and ground for the PCM then replace it with a used up here is the locations guide and wiring diagrams to do so.
Apr 2, 2018 at 8:06 PM
MARVIN OLSON
  • 9 POSTS
Well thanks for being so helpful and responding. The codes meant nothing like you said but somehow with taking the fuel pump relay and the eec power relay apart from their connectors and putting them back together again many times while testing them when I was checking the codes while turning the key off and on I noticed that the fuel pump started cycling. I had put on a new fuel pressure regulator on which was the original problem but didn't start the pump. The motor started today and finally smoothed out after awhile but I am going to check the fuel pressure when I can get a fuel pressure tester.Thank you so much for this web site that we can share our problems and you bare with us and I will keep an eye out to maybe help someone else.A word to the wise if your fuel injected motor starts flooding don't keep trying the engine will never be the same. THANK AGAIN
Apr 3, 2018 at 5:16 PM
Good call. Let me know what happens :)
Apr 4, 2018 at 10:27 AM
MARVIN OLSON
  • 9 POSTS
Hey sorry I haven't got back to you but have been away. I finally tested the fuel pump on the rail and got 35 lbs with the switch on and then when I started the motor there is 30 lbs or a little less if it is reved up. Should there be bit more. Thanks for being patient.
Apr 9, 2018 at 11:00 AM
That sounds normal. Does the engine run on starting fluid?
Key On Engine Off 35 - 45 psi
Key On Engine Running 30 - 40 psi
Please run this test and get back to us.
Apr 9, 2018 at 3:54 PM
MARVIN OLSON
  • 9 POSTS
Thanks for the reply. The engine runs and I have had it for a drive. It won't idle very long stopped before it stalls but starts right up again. I here the pump cycling and when the engine stops the pump pressures up and stops till I start it again. When the motor is running it serges then stalls if I don't keep my foot on the pedal some then it will keep running. Thanks again
Apr 10, 2018 at 11:40 AM
Can you tell me if the engine stalls when you are coming to a stop? can you video the car and upload it here in your response?
Apr 10, 2018 at 5:45 PM
MARVIN OLSON
  • 9 POSTS
I can come to a stop put it in park then it stalls out sitting idling.Sorry I am not able to video or upload don't have the right technology I am from the old school. I can keep my foot on the pedal a bit and it will keep running. No real adjustment on the linkage to speed up the motor a little bit as you could on the old vehicles with a carb. Thanks for staying with me.
Apr 14, 2018 at 3:39 PM
It sounds like you have a vacuum leak or an IAC motor that is not working right can you please run down these guides to see what you find.
https://www.2carpros.com/articles/stall-at-idle
and
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Apr 16, 2018 at 9:01 AM
MARVIN OLSON
  • 9 POSTS
Thanks again. I will check things out but have been busy with work. Maybe awhile getting results.
Apr 19, 2018 at 8:52 AM
Please let us know.
Apr 19, 2018 at 10:30 AM
