Fuel problem
2002 NISSAN X-TRAIL
120,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
SKELLEY CHRIS
I have a diesel that has developed a strange problem. Whilst driving started jerking and shaking eventually stalling. All alternator battery lights okay. Start ignition again, starts okay, but is misfiring when press gas pedal. then after one hundred km or so starts same problem jerking and then stalls. I go to garage and they diagnose a fuel filter. Its replaced and all is okay again for about three hundred km then problem starts again. This time does not stall and idles perfectly. Can it just be dirty diesel and the fuel filter needs cleaning again? Or something else like sensors? If bad diesel any idea how to clean it?
May 13, 2017 at 3:15 AM
CARADIODOC
  • 34,306 POSTS
I'm only poking my nose in here because I see you've been waiting a while for a reply. Part of your description of the symptoms could be attributed to an elusive cause that creates a similar problem with gas engines. That is a collapsing or plugged pick-up screen inside the fuel tank. If your vehicle uses a low-pressure fuel pump in the tank, you can verify this by attaching a fuel pressure gauge, then watching what happens to pressure when the problem occurs. If this is not a viable solution, consider posting a new question so the other experts will see it and have a chance to reply. Now that I posted this reply, this question shows up as having received a reply already, so most of us won't read your request for help. That does you a disservice if you wait for me to come up with something better.
May 13, 2017 at 9:19 PM
