Truck runs really rough with a full tank
2002 CHEVROLET 2500
250,000 MILES • 0.6L • V8 • 4WD • AUTOMATIC
TRAVIS FRANKS
Runs much better when it’s about out of gas.
Dec 6, 2020 at 10:46 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
If it runs rough like that it's possible it has set a fault code. It sounds like some type of fuel delivery problem. Is the check engine light on or has it been flashing when this happens? If so then the first thing to do is check the codes stored in your trucks computer. If you don't have access to a scanner or code reader most auto parts stores have a tool loaner program and can rent you one. Auto parts stores like AutoZone will check codes for free. Here is a tutorial showing what is involved for retrieving codes:
After performing this get back to us with the code information and we can then properly diagnose this issue on your truck. Hope this helps and thanks for using 2CarPros.
Dec 7, 2020 at 2:28 AM
