Yeah, those numbers are maxed out rich. Do you have a voltage level for the Bank 1 Sensor 2 Oxygen sensor? I think the 99% is a substituted value, so if there is a high voltage reading on B1 sensor 2- 02 sensor, that's also shows an actual over fueling condition.
I will be back with you shortly, not sure what time zone you are in, but if you can check the spark plugs on that side without too much trouble it will help in diagnosing leaking injectors,
It looks like this vehicle has a mass air flow (MAF) sensor and a Map sensor, The MAF will read in g/s (grams per second) and should be around 3.4-4g/s at idle, so if it is over reporting air flow, such as 7-8 g/s of air flow, the ECM will add fuel to the mixture due to that, if there is a data PID for the MAF.
It looks like the 02 sensors are reacting to the rich mixture correctly but see if you can find MAF data (Mass Air Flow).
But the -26% is pegged out. With the front B1 sensor taking away so much fuel, and if you find that the B1 sensor 2 is reading 0.9v (900mv) as well, then you know there is way too much fuel being dumped into the intake manifold, your oil is now diluted with gasoline as well. So, you need to change your oil as soon as you figure out what's causing this.
As for if this is leaking injectors, the only way to know exactly is to either get a camera down into a suspect cylinder to see the injector leaking, or discharge the fuel pressure, and pull up the fuel rail, prime the fuel pump with key on only. and see if they leak out of the intake manifold. Without the pulse tool to measure the pressure loss of each injector, a physical inspection is the only way to be sure.
If you have access to a borescope to look right down a spark plug hole, to see fuel leaking into the cylinders. But this will destroy the catalytic converter if its driver like this much longer.
Sep 25, 2023 at 5:28 PM
