AllData lists 52- 58 psi for a 2000 Grand Am with either engine.
1999 Grand Am 2.4L with EGR, and 3.4L: 41 - 47 psi.
1999 Grand Am 2.4L without EGR: 52 - 58 psi
Some numbers come up different depending on where you find them. The engineers can't make up their mind, and it appears some service manuals don't agree either. Years ago there were over two dozen part numbers for PCV valves for one model year. They only thing you didn't have to know to get the right part was the car's paint color.
The best thing I can suggest is what I mentioned about pinching the fuel return hose. If fuel pressure jumps up, that proves the fuel pump is able to develop a higher pressure. At that point, if pressure is too low, it's either a pressure regulator problem or a volume problem. Be aware Chrysler and GM fuel pumps fail in very different ways. GM pumps almost always start up, then they slow down when they get hot after driving a while. Most complaints refer to power loss or stalling while driving. Those failing pumps often work again after cooling down for a while.
Chrysler pumps fail by failing to start up, leaving you sitting in the driveway or parking lot. Banging on the gas tank sometimes gets them going, then the same problem could occur at the next start-up, or not again for a few months. Once they're running, it's just about unheard of for one to quit while driving unless there's a wiring or connector terminal problem. Fuel pressure problems rarely enter the equation on Chrysler products.
With GM or Chrysler models, before you condemn a fuel pump due to low pressure, perform a volume test, especially if a problem develops after driving a few miles. A common cause of volume dropping off is a plugged strainer, or "sock" on the fuel pump housing. Don't waste your time replacing a fuel filler on a Chrysler product unless it has rusted out and is leaking. They commonly last the life of the vehicle. The same is not true of those strainers. A clue the strainer is plugged is the engine will run best at highway speed and when accelerating. Stalling will occur repeatedly when the highest volume of fuel is being pumped, which is during coasting.
GM fuel filters do need to be replaced periodically, but the clues are different. Any problem they cause doesn't get worse the longer you drive, like it does with a plugged strainer, and the engine won't run better when it's cold.
Here's links to some articles you might find of interest:
https://www.2carpros.com/articles/signs-of-a-clogged-fuel-filter-in-your-car-symptoms-to-watch
Let me know if I missed anything.
Jun 6, 2023 at 3:22 PM
