Code P0090, fuel pressure regulator open circuit, diagram for this high-pressure pump volt signals input and output needed?
2015 HYUNDAI SANTA FE
125,050 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
ANDRIN ATEM
  • 393 POSTS
Hi, please can you provide me with the diagram for this high-pressure pump volt signals input and output, so I can compare if it’s within specification.
Fault code is P0090.
My current voltage reading is 1.44 on one cable with key on run position.
While the other cable I am getting a voltage of 1.49 with key on the run position. Please help me with the diagram and the signal outputs and inputs.
Sorry it’s All wheel drive.
Dec 23, 2024 at 10:30 AM
Chances are there is a connector issue. At the voltages to the regulator, the first three pics below are specific to the code. They provide what to check and the specifications expected.
Pics 3 and 4, they are from the powertrain management wiring schematic. There should be two wires at the regulator. One high voltage and the other is a low voltage signal. Black is the high, blue is the low.
The second picture below is the pinout from the PCM.
Take care and Merry Christmas!!!
joe
See pics below.
Dec 23, 2024 at 8:39 PM
ANDRIN ATEM
  • 393 POSTS
Thanks very much for the diagrams.
Dec 24, 2024 at 3:00 AM
ANDRIN ATEM
  • 393 POSTS
What module is this please? It’s certainly not the ecu. Because I can see the two terminals for the fuel pressure Regulator. I have added the VIN number on the images below.
From the ecu pin out I can see the fuel pressure regulator.
Dec 24, 2024 at 3:02 AM
The high-pressure pump regulator goes to the injector driver box. Here is the location. Check out the images (below). Let us know how it goes.
Dec 26, 2024 at 11:44 AM
ANDRIN ATEM
  • 393 POSTS
Please confirm the VIN number if this diagram is for the correct vehicle.
Below I have attached the VIN number for my vehicle.
Dec 26, 2024 at 2:09 PM
ANDRIN ATEM
  • 393 POSTS
Below I have attached the vin number for my vehicle.
Yep, the information has been confirmed for your vehicle.
Dec 27, 2024 at 10:26 AM
ANDRIN ATEM
  • 393 POSTS
Thank you.
Dec 28, 2024 at 1:28 AM
You are welcome, please let us know what happens.
Dec 28, 2024 at 10:14 AM
ANDRIN ATEM
  • 393 POSTS
Thank you, I will.
Dec 28, 2024 at 3:37 PM
