Why would a fuel pressure regulator completely block the flow of fuel into the fuel bar?
2000 VOLVO V40
150,000 MILES
SQRTFRME
  • 6 POSTS
Why would a fuel pressure regulator completely block the flow of fuel into the fuel bar like the pump works it pressurizes all the way up to the fuel pressure regulator I've replaced the fuel pressure regulator twice and I still am getting no gas past the fuel pressure regulator.
Sep 25, 2024 at 12:00 PM
That honestly doesn't make sense. I understand your confusion. If you have pressure to the regulator, try applying vacuum to the regulator to see if the fuel moves through it.
If that doesn't change anything, remove the regulator from the engine, connect the fuel supply, and place the regulator into a container to catch fuel. Turn the key to the run position and see if fuel comes out of the regulator. If it does, something in the fuel rail is stopping the fuel flow.
Try that and let me know what you find.
Sep 26, 2024 at 12:59 PM
SQRTFRME
  • 6 POSTS
So, we have removed the whole unit from the engine and when gas is applied to it, it still does nothing the fuel rail bar is clear all the way through to the end you can see with flashlight and has no relays attached to it when looking at up the unit I bought has a 48 PSI rating and the unit originally for my car has a 45 but that's a negligible difference and it really shouldn't be causing an entire stop in the fuel flow I am still at a loss.
Sep 26, 2024 at 1:25 PM
SQRTFRME
  • 6 POSTS
And we have applied vacuum and replaced the vacuum line to it as some places said that even a small hole could cause the whole unit too malfunction which I don't entirely understand either because on startup there's no vacuum really there to begin with once it's running I could understand the vacuum being necessary but just starting the car it should just be a squirt.
Sep 26, 2024 at 1:27 PM
Is the quick connector original?
Sep 26, 2024 at 6:01 PM
SQRTFRME
  • 6 POSTS
Yes, but the new regulator insert isn't.
Sep 26, 2024 at 6:35 PM
Is the new insert the same as the original one? Something has to be blocking or preventing the fuel from leaving the fuel line.
Sep 27, 2024 at 7:11 PM
SQRTFRME
  • 6 POSTS
No it's not they sold me one with a 48 PSI the original is 45psi but that shouldn't be enough of a difference too entirely stop the flow.
Sep 27, 2024 at 7:46 PM
I agree with you, but at this point, that seems to be the only possibility.
Sep 27, 2024 at 7:55 PM
SQRTFRME
  • 6 POSTS
Well, I ordered another one that is supposed to be proper for the car at the 45 PSI I will let you know if that changes anything whenever it comes in.
Sep 27, 2024 at 9:12 PM
Thanks for the update. I look forward to hearing from you. I'm interested in knowing if that is the issue.
Sep 28, 2024 at 6:23 PM
