Fuel pressure regulator
2008 KIA SORENTO
160,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JBRCLARK
Car cranks for ten to thirty seconds with pedal down before turning over. Takes longer when engine is cold but still cranks for five to ten seconds if warm as well, just turns over quicker. Car runs totally fine once started. Battery checked and read good but needs charging but still did it after driving around for twenty minutes to build up a charge. Leaning toward the pressure regulator but cannot seem to find a good diagram to be sure of the location. Do most of my own repairs but learning as I go. Does anyone have a better diagram or instructions on where the fuel rod is and the regulator? I feel like I see the rod but half of it is under the manifold. Do I need to remove the manifold to access it? Also, if you have an additional thought on what it could be much appreciated.
Other symptom happening but may not be related is engine pulses while decelerating.
Sep 15, 2018 at 10:41 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Have you check the fuel pressure on the fuel rail at the Schrader valve? You might want to check the pump pressure first as the fuel pump may be weak. Your local auto parts stores (Pep Boys,O'Reilly's, Autozone) have a tool loaner program and rent you one. I would try this first. I have attached a tutorial show what is involved in the testing. Hope this helps and feel free to ask any questions.Thanks for using 2CarPros.
Danny-
Sep 15, 2018 at 2:14 PM
JBRCLARK
That is great advice I will try that tonight. Thank you very much.
Sep 15, 2018 at 2:36 PM
DANNY L
  • 5,648 POSTS
You are welcome!
Let us know what happens. Fuel pressure should be 54-55 P.S.I. Thanks again for using 2CarPros.
Danny-
Sep 15, 2018 at 5:11 PM
