Crank no start, security light turns on?
2001 GMC JIMMY
250,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
AMIZZELL44
The car will turn over and crank but only if you spray ether on iban now when you try to crank it the security light comes on. Fuel pressure issues?
Jun 26, 2023 at 12:38 PM
Is the security light flashing? does the engine run on starting fluid? Also, we should run the codes to see what comes up.
and
https://www.2carpros.com/articles/car-not-running-advanced
Do you hear the fuel pump kick on when you turn the key on but not crank the engine over? Please go over these guides and get back to us.
Jun 26, 2023 at 6:54 PM
AMIZZELL44
The security keeps flashing when you try to crank the truck. I can hear the fuel pump coming on.
Jun 26, 2023 at 7:39 PM
AMIZZELL44
What is the normal fuel pressure supposed to be? because ours is between 20 and 40 PSI.
Jun 26, 2023 at 7:40 PM
It looks like you found the problem, here is the fuel pressure stats:
Key On Engine Off .................... 60-66 psi
Here is how to change the fuel pump out. Check out the images (below). Please let us know what happens.
Jun 27, 2023 at 10:02 AM
